lift issue
4d4life
lift issue
Post by 4d4life » Fri Jul 06, 2012 6:34 pm
Just lifted my 88 bronco ii and now I have a possative camberthe alignment shop won't touch it until the camber is fixed. Help would be great :) I will post pics if needed.
Jbots
Re: lift issue
Post by Jbots » Sun Jul 08, 2012 12:04 am
You need to get some drop brackets for the ttb system in the front, that and extended camber bushings
tedjames11
Re: lift issue
Post by tedjames11 » Sun Mar 24, 2013 8:31 am
If you can find were to buy just the drop brackets could you send me a link to were you found them? I cant locate just the brackets anywere. I would LOVE to just make them so id be cheaper but I cant find them for sale let alone the schematics. :rolleyes:
Mudhog1977
Re: lift issue
Post by Mudhog1977 » Tue Mar 26, 2013 11:42 am
Try James duff enterprises
iceman21
Re: lift issue
Post by iceman21 » Thu May 23, 2013 12:18 am
Make your own. They Arnt that hard to make.
tedjames11
Re: lift issue
Post by tedjames11 » Tue Jul 09, 2013 10:52 am
did you have any luck at finding the schematics?
Lifted_B2
Re: lift issue
Post by Lifted_B2 » Thu Aug 21, 2014 6:07 pm
i also lifted my 84' drop brackets and everything. i still have very bad positive camber issues. can anyone help, it might be to stiff of springs but im unsure
2813josh
Re: lift issue
Post by 2813josh » Thu Nov 06, 2014 6:41 pm
You'll need to get camber bushings. Have to press out the ball joints to install.
Rock Auto sells them in varying degrees of adjustment.
