lift issue
lift issue
Just lifted my 88 bronco ii and now I have a possative camberthe alignment shop won't touch it until the camber is fixed. Help would be great :) I will post pics if needed.
Re: lift issue
You need to get some drop brackets for the ttb system in the front, that and extended camber bushings
tedjames11
Re: lift issue
If you can find were to buy just the drop brackets could you send me a link to were you found them? I cant locate just the brackets anywere. I would LOVE to just make them so id be cheaper but I cant find them for sale let alone the schematics.
Mudhog1977
Re: lift issue
Make your own. They Arnt that hard to make.
tedjames11
Re: lift issue
did you have any luck at finding the schematics?
Re: lift issue
i also lifted my 84' drop brackets and everything. i still have very bad positive camber issues. can anyone help, it might be to stiff of springs but im unsure
Re: lift issue
You'll need to get camber bushings. Have to press out the ball joints to install.
Rock Auto sells them in varying degrees of adjustment.
