b2 dash
b2 dash
I got an 85 b2 and was wondering if a 90 dash would fit. Im guessing i would have to get ducting for the a/c but i dont know how much work it would be
Re: b2 dash
It seems to me that there was a common swap of the 90 BII dash into the older ones. I think It may even have been a first gen explorer dash.
I remember when it is was done, when someone put a 4.0 in their BII. The person doing it found it was easier to swap the 4.0 by using the under hood and main harness from the donor vehicle. They had to use the cab harness and dash harness but I remembered it was nice but a lot of work. Ya might do a search on here for new dash. If you don't find it try The Ranger Station.com or bronco II.org. between here and the other two resources you should find enough answers to at least answer your questions.
Re: b2 dash
Cool thanks for the info
