confused on tires and rims
Postby 4d4life » Tue May 08, 2012 11:34 am
just installed 2" spacers up front and add a leafs in the rear. I was wondering what would be the the best sized rims and tires that wont rub or require any trimming. Thanks
Re: confused on tires and rims
Postby iceman21 » Fri Nov 02, 2012 10:55 pm
Well considering I was a able to put 31/10.50/15 on my bonestock 87' b2, you should be able to fit a 33" on 15" rim with that 2" lift and it wouldn't require any trimming
Postby Mudhog1977 » Tue Nov 06, 2012 3:54 am
33's will rub better off with 31's
Postby rusty7983 » Thu Dec 27, 2012 8:03 am
Did you have any alignment issues with the blocks? MY camber is out of control. Sunday my ex takes the girls again and I may have to pull them out.
