Brake light Fuse keeps blowing
I have been restoring an 85 B2. One of the issues I have is the brake light fuse in the fuse box keeps blowing. I bought it last year and the brake lights were not working so I replaced the brake sensor on brake pedal along with a lot of missing fuses. It worked fine for like 6 months and then it would blow the brake light fuse every once in a while but now it blows all the time. I've looked for shorts, Any help?
Re: Brake light Fuse keeps blowing
Something grounded out sometimes it may be a bad light socket I've seen that happen before but honestly I think u might have a wire rubbed raw or something to that effect and its just grounding out
If it won't do it when you turn on the turn signals it's not the socket or bulbs.. I'm thinking muti-function swt or wiring from brake swt to muti- function swt.
I just had another thought. The speed control on the same curcuit
thanks, I am having the multifunction switch replaced because of another issue, hopefully it will fix it.
If that don't work a large ball of tinfoil goes a long way!
