Finally got around to draining and refilling axle oils on my BII....rear was dark and sludgy while the front was nice and golden still.
Haven't driven it a ton yet but I have yet to hear the popping noise so I'm thinking the fluid swap did the trick....
loud rearend noise
Re: loud rearend noise
Hey hopin some of y'all are still around I'm in need of new tires my 88 bronco ii is all stock with stock rims could I get 30x9.5 r15 on it? I don't mind a little rubbing I can just get all four tires for 100 here's the tires https://www.treadwright.com/p-6-30-9-50r15-puma.aspx
If your oil was all sludgy.i would change it again and replace the wheel seals and probably the pinion seal.
Thanks for the tip...
