1984 bronco 2 2.8 v6 water outlet housing
I have been having an issue finding this upper thermostat housing aka water outlet. I've been told thier discontinued I've called every junk yard in Michigan even eBay and no luck. Is there a way to use an aftermarket one and reroute the heatercore hoses? Thanks so much. Been stranded for a month!!!!
Re: 1984 bronco 2 2.8 v6 water outlet housing
dude i got one
Want to get rid of it, just had mine welded with nickle the guy burnt a hole straight through it.
pm or post the picture of it
Napa online part number BK6051182
yeah I defiantly have one
It looks like the Napa one may be a bottom water outlet even if it say upper
well if the number for the one you gave me you think might be wrong take a picture of the one you have even if it's messed up
I don't remember if the outlet for the 2.8L has a heat hose connection. The one on Napa Online says it's for an 2.8L upper but the picture doesn't have a heat hose nipple on it. It's sounds like it may be what Breal is looking for a water outlet with heat hose nipple on it. I'm sure Dave would know. Been awhile since I've worked on 2.8Ls. Breal go to napaonline.com and put the part # in and see if that's the one.
Thanks for the help, how hard is it to put a 302 in it.
do a search. it's been talked a lot here
The difficulty of installing a V8 in your bronco II is inversely proportional to the root of the number of dollars you have to spend.Breal wrote:Thanks for the help, how hard is it to put a 302 in it.
In other words if ya gotta bundle it is a piece of cake.
1100 for the kit from bronco graveyard.com comes with motor mounts, oil pan, remote oil filter kit, and headers
lol dont forget about the either adapter bell housing or advanced adapter for the transmission to t case
