1984 bronco 2 2.8 v6 water outlet housing
Breal
Post by Breal »
I have been having an issue finding this upper thermostat housing aka water outlet. I've been told thier discontinued I've called every junk yard in Michigan even eBay and no luck. Is there a way to use an aftermarket one and reroute the heatercore hoses? Thanks so much. Been stranded for a month!!!!
101btp
Re: 1984 bronco 2 2.8 v6 water outlet housing
Post by 101btp »
dude i got one
Breal
Post by Breal »
Want to get rid of it, just had mine welded with nickle the guy burnt a hole straight through it.
101btp
Post by 101btp »
pm or post the picture of it
drofman
Post by drofman »
Napa online part number BK6051182
101btp
Post by 101btp »
yeah I defiantly have one
drofman
Post by drofman »
It looks like the Napa one may be a bottom water outlet even if it say upper
101btp
Post by 101btp »
well if the number for the one you gave me you think might be wrong take a picture of the one you have even if it's messed up
drofman
Post by drofman »
I don't remember if the outlet for the 2.8L has a heat hose connection. The one on Napa Online says it's for an 2.8L upper but the picture doesn't have a heat hose nipple on it. It's sounds like it may be what Breal is looking for a water outlet with heat hose nipple on it. I'm sure Dave would know. Been awhile since I've worked on 2.8Ls. Breal go to napaonline.com and put the part # in and see if that's the one.
Breal
Post by Breal »
Thanks for the help, how hard is it to put a 302 in it.
drofman
Post by drofman »
do a search. it's been talked a lot here
Post by tekatlarge »
Breal wrote:Thanks for the help, how hard is it to put a 302 in it.
The difficulty of installing a V8 in your bronco II is inversely proportional to the root of the number of dollars you have to spend.
In other words if ya gotta bundle it is a piece of cake. :cool:
Mudhog1977
Post by Mudhog1977 »
1100 for the kit from bronco graveyard.com comes with motor mounts, oil pan, remote oil filter kit, and headers
101btp
Post by 101btp »
lol dont forget about the either adapter bell housing or advanced adapter for the transmission to t case
