2 in body lift?
Milton deal
2 in body lift?
Post by Milton deal »
hey i was wondering if i could do a 2 in body lift and fit 31 in tires on her later.......also does this change off road performance?steering?any thing i should no b4 i start
Re: 2 in body lift?
yeah, you will fit 31's with the body lift. You could probably fit them now with a little bit of trimming. Make sure to get the steering extension with the lift. It will make you feel a little top heavy but it will give you no real advantage off road other then it will let you run bigger tires.
