89 b2 wit a 302 question
---muddigger---
Post by ---muddigger--- »
yo i got a 89 wit a 302 in it :D runs strong as hell n is pushin 400hp beleive it or not :finger: but when i go to shut it off i turn the key to off n it still wants to run. it kinda putters llike its gunna conk then it shuts off. any tips? :confused: thx
Re: 89 b2 wit a 302 question
retard the timming a little,or turn the idle down. whats the specs on the motor
drofman
Post by drofman »
beat me to it Dave
---muddigger---
well i jus got the beast. its a 4 barrel bored out 302 with: 650 eb carb, long tube headers, no cats, flomaster dual 40s, dual pushers, aod trans, the entire engine is rebuilt with aftermarket cams, pistons, rods , n manifold. theres even more stuff done to it that im forgetin. anyway its lifted 7" w/33 but im goin t0 35s
Try running some high octane gas. If it's a built engine, then it might have a high compression ratio, causing it to detonate once the ignition is turned off.
---muddigger---
yeah i gotta try it n im gunna adjust the carb too thx
justinC
Post by justinC »
you should try retarding the timing because if its to far advanced it will cause excess heat in the cylinder thus allowing the gas to detonate with out spark. A couple degrees will make a difference.
justinC wrote:you should try retarding the timing because if its to far advanced it will cause excess heat in the cylinder thus allowing the gas to detonate with out spark. A couple degrees will make a difference.
Ranger Dave wrote:retard the timming a little,or turn the idle down.
didnt i say that
---muddigger---
yeah thx guys. problem solved. good as new
---muddigger--- wrote:yeah thx guys. problem solved. good as new
soooo,you gonna tell us or want, we told you what to try
---muddigger---
the throttle was stickin a lil so i made a braket n put a spring on it to make a throttle return n its perfect now
