BII 302 Tranny Questions
Dreded
Post by Dreded » Wed Apr 13, 2011 1:17 pm
Before people give me grief I searched.. its all just so confusing lol
I have a BII w/302 and a M50D mated to a BW1356 now this thing is WAY to long and wide... I want to install a shorter manual tranny as simply as possible so any suggestions would be great
I was thinking the NP435 mated to a NP205 from what I can figure those came in 1975 to 1982 F-series correct? do I need to swap my flywheel? will a flywheel from a donor vehicle always work?(like if I had an entire F-series truck w the NP435/205 do I just use the flywheel on the truck?) whats the shortest bell housing available? also if the donor vehicle ends up being a 6cyl would a flywheel from a 6cyl work on the 302?
Oh and whats easiest way to deal with clutch? currently on the M50D i used the stock BII master and used a compression fitting to splice the Hydrolic lines together
I know lots of questions and I have just spent the last 5hours reading stuff and am still confused... also availability of parts/price is a factor the np435 seems readily available what other t-cases mate directly/easily?
4x4'ers Eat More Bush!
Dreded
Re: BII 302 Tranny Questions
Post by Dreded » Wed Apr 13, 2011 1:21 pm
also the reason I am doing this now is because I just blew my rear drive shaft and a month ago the front took a nasty hit so I have to replace my drive shafts anyhow so I figured its a good time to get a better setup under there
Post by DBrown » Sat Apr 16, 2011 3:44 pm
your flywheel will work with the NP435, but it will work better if you get the hydro bell housing. I am installing a NP435/205 combo in my f100 if you want me to give you a measurment. I think the bell housngs are the same but you might want to check on the starter location just to make sure. also the low range of the 205 is only 2:1 so you will loose there and the NP435 dosen't have OD.
Post by Ranger Dave » Sat Apr 16, 2011 4:08 pm
find a 84 ta 87 F150 and get the hyd bell from it. it has the external slave. then the 435/205 will fit right in. the 205 is the same width as the 1350.
Post by Ranger Dave » Sat Apr 16, 2011 4:12 pm
Dreded
Post by Dreded » Tue Apr 19, 2011 9:42 am
thanks for the help... is there any other Transfer cases that fit under the BII nicely and mate to the NP435?
Post by Ranger Dave » Tue Apr 19, 2011 3:40 pm
none that i know of that will fit with out cuttin the frame. theres is a 435/D20 combo,but ya need a adapter. i have one for sale
http://nh.craigslist.org/pts/2330115024.html
http://rangerdave.freeforums.org/dana20 ... -t262.html
Dreded
Post by Dreded » Tue Apr 19, 2011 10:51 pm
Ranger Dave wrote:none that i know of that will fit with out cuttin the frame. theres is a 435/D20 combo,but ya need a adapter. i have one for sale
I would totally buy that but unfortunately I am in Vancouver BC :-\
If you are willing to ship then heres a few questions...
Got Paypal?
How much does it weigh?(so I can check shipping)
ZipCode?
come with the bellhousing?
Was it in use? or Unknown Condition?
Post by Ranger Dave » Wed Apr 20, 2011 3:40 am
i would cost waaaay to much to ship. the tranny weights around 120ish and the tcase about 50ish. thats pounds
Dreded
Post by Dreded » Wed Apr 20, 2011 10:29 am
175lbs shipped UPS freight would be $650 USD lol
I ship stuff across Canada(2700miles) all the time for $40 CDN for 120lbs/pallet Ill check into it later to see if I can find a decent freight company for the U.S. :p
