my new 88 b2 is my new project, i have wheels and tires on lock but the next step is to lift it and have a nice base to start my project out on. my thoughts were a 4 inch suspension lift and a two or three inch body lift. I'm planing on going with 31x10.50x15 wheels and tires. is there anything special i should know before lifting it? do i need longer brake lines/drive shaft, special tools, etc... any advise would be appreciated, thanks!
-Ben-
lift kit tech
- Mud Addict
Re: lift kit tech
2in of lift is plenty for 31's
Re: lift kit tech
my 88 has a 3" body lift and 31's rub a little if i turn the wheel to the stops
Re: lift kit tech
justinC wrote:my 88 has a 3" body lift and 31's rub a little if i turn the wheel to the stops
rubs on what??
Re: lift kit tech
not sure i havent had much of a chance to look at it. i only got to drive it for a day and the flex plate broke so it has been in the shop almost a month. i only noticed a couple of times.
