rebuilding a 302?
PetesPonies
Re: rebuilding a 302?
Post by PetesPonies » Thu Mar 10, 2011 6:49 am
Well Ranger Dave, you are close . . but the "E" in the casting number does not mean engine. The "T" does mean the truck division was responsible for the design, but doesn't mean it can't be used in other vehicle lines; which they were.
Pete's Ponies
Mustang RUSToration & Performance
Post by Ranger Dave » Thu Mar 10, 2011 1:13 pm
ok, how bout this
E= engine group
101btp
Post by 101btp » Fri Mar 11, 2011 8:10 am
101btp wrote:well I took off the head and their was a little rust in the bore so i used a bore hone lightly and cleaned it best I could now I was told this was from a 77 crown vic? but has the casting e7te?
well hears the pistons I have in the block and it's an e7te block, but it has the e6se cylinder heads and I was just wondering if it's worth me porting polishing new valves new springs or to use a different stock head and do the same, ive also been wondering if one of the 351 heads would work with those pistons, just trying to find something that the valves wont run into the piston theirs not much depth carved into the pistons either, and seems about 1/3 of people like the heads and the other 2/3 don't? and this is an 87 roller block that i do plan on getting a cam for but again depending on what heads i go with?
o and Yankee lake is coming up soon so my time to figure things out is starting to run low
http://www.trucknight.com/index.php
ok so now it gets a little more confusing im getting a lot of mixed messages on the e6se heads and people are saying their pretty good for torque? and some are saying they suck??
o and lets not forget that i need to find a new transfer case
and figure out on how to run the fule I was told take the high pressure pump off on the frame keep sending unit in the tank and use a regulator possibly with a return to the tank, im also trying to understand with having the pump in the tank will their be a need for a mechanical pump on the block
101btp
Post by 101btp » Tue Mar 15, 2011 6:50 am
the heads I will be going with are gt-40 heads
101btp
Post by 101btp » Sat Mar 19, 2011 12:42 pm
dose any one know the psi ratings for the in tank sending unit pump?
Post by DBrown » Sun Mar 20, 2011 2:12 pm
you could hook a pressure guage to the line and turn the key to the on position to find out. you going carb or EFI?
101btp
Post by 101btp » Sun Mar 20, 2011 7:22 pm
im using a carb and yeah it's a low budget build for now anyways and this will also save on doing more work than I have to I can use the low pressure pump in the tank and just remove the one on the frame, use a pressure regulator and be fine
drofman
Post by drofman » Mon Mar 21, 2011 7:34 am
the 88' Ford truck shop manual gives the high pressure at 35 to 45 psi ( I've never seen 45) but only gives flow rate for low pressure pump. 16 oz of fuel in ten seconds. use the high pressure and put a regulator on it like you would with a good electric pump.
101btp
Post by 101btp » Mon Mar 21, 2011 8:05 am
now im not all that familiar with regulators but what would be the benefit of having a return to the tank on it?
drofman
Post by drofman » Mon Mar 21, 2011 8:45 am
forgot about that. Tech or someone may know if you need a return and tell you if I'm talking out of my a**. I was talking about the in-line type of regulator with the dial 1 thur 10 on it to regulate pressure.
101btp
Post by 101btp » Mon Mar 21, 2011 10:07 am
yeah I know what you were meaning I was just worried about it having too much back pressure?
Post by tekatlarge » Wed Mar 23, 2011 7:34 pm
You can get an adjustable fuel pressure regulator of the bypass type. They allow you to dial any pressure you want and it keeps the pumps from having to work their guts out. Check summit or Jegs..
Kent,Worshington
drofman
Post by drofman » Wed Mar 23, 2011 7:41 pm
I knew Tek would know
Post by tekatlarge » Wed Mar 23, 2011 7:51 pm
Thanks for the compliment drofman.
Kent,Worshington
101btp
Post by 101btp » Thu Mar 24, 2011 8:08 am
alright thanks : )
had another small setback today broke the timing cover taking the water pump off
