tire size?
Posted: Thu Dec 23, 2010 6:11 pm
by 1986B2
could i fit 31-10.5-15s on 15x10 rims on my 86 b2 with 2" rear blocks and 2" front coil spacers? and also will i need sway bar drop brackets or skyjacker alignment bushings?
Re: tire size?
Posted: Sun Apr 17, 2011 10:18 pm
by green45
you should beable to i have 36s under mine and i only have a 4inch lift granit i use mine for wheeling so i took my sway bars off
Re: tire size?
Posted: Sun Apr 17, 2011 11:12 pm
by Mud Addict
Yes, I was running 31's on stock rims with 2in lift
Re: tire size?
Posted: Tue May 03, 2011 7:56 pm
by Mudhog1977
stock sway bar brackets will work, do need alignment bushings and a front end alignment, bit the front tires will rub a lil bit when u turn
