tire size?
1986B2
tire size?
Post by 1986B2 » Thu Dec 23, 2010 6:11 pm
could i fit 31-10.5-15s on 15x10 rims on my 86 b2 with 2" rear blocks and 2" front coil spacers? and also will i need sway bar drop brackets or skyjacker alignment bushings?
green45
Re: tire size?
Post by green45 » Sun Apr 17, 2011 10:18 pm
you should beable to i have 36s under mine and i only have a 4inch lift granit i use mine for wheeling so i took my sway bars off
Mud Addict
Re: tire size?
Post by Mud Addict » Sun Apr 17, 2011 11:12 pm
Yes, I was running 31's on stock rims with 2in lift :cool:
Mudhog1977
Re: tire size?
Post by Mudhog1977 » Tue May 03, 2011 7:56 pm
stock sway bar brackets will work, do need alignment bushings and a front end alignment, bit the front tires will rub a lil bit when u turn
