2" lift questions...
On my 86 b2 4x4 could i put 2" rear lift blocks and 2" coil spacers on the front without getting swaybar and radius arm drop brackets?? also what size tire could i clear with that? I have a set of 15x10 wheels for it.
Re: 2" lift questions...
You could clear 31 x 15 x 10.5 that what i have on my 85 . But they do make a cheap 3 inch lift for about 300 comes with all the drop brackets
so you have 2"s of lift with 31's?
I put 31's on my 84 BII still needed a 3 inch body lift to clear so front wouldnt rub when turning
then you have some really weak springsbroncofan wrote:I put 31's on my 84 BII still needed a 3 inch body lift to clear so front wouldnt rub when turning
Thanks dave, really never thought about that. Now i need to look for some springs. LOL
I was following this thread and want to know what springs are commonly used? I have a set of 31's and 33's but do not know what is used for lifting.
Thanks
Thanks
you can get a couple inches using xplorer springs
