Bronco starting question
garagedude
Post by garagedude »
Whats the relay( I think) on the firewall for? I've tryed shorting the solonoid and cleaned every connection but it won't start or crank. The starter tested good. It sounds like that relay thing on the firewall is clicking? Is it needed ?? Its like a fuseblock thing. The parts store don't carry this either...
I May get Lost But I Don't Get Stuck
84 BroncoII, Locked, Winched, Big Tires,
oneway
Re: Bronco starting question
Post by oneway »
is there a bad fuse?
clicking means a bad starter/alternator
if it cranks but won't turn over = bad battery
right?
have you tested for spark?
1990 Bronco II 4x4 2.9 auto
drofman
Post by drofman »
clicking means battery. have you tested the battery? or jumped it with cables from another car? to jump the relay take a wire from battery "+" to the "S" terminal
drofman
Post by drofman »
NAPA # ECH STH404 for relay. looks different but will work
