1985 Bronco II 2.8 L Will not advance
John R
Post by John R »
The motor will start and idle without a problem but if you try to accelerate it will not advance. We put a timimg light on it an verified that it is not advancing. This is controled by the electonics module. Any suggestions? Thank You!
Ruffinit
Re: 1985 Bronco II 2.8 L Will not advance
Post by Ruffinit »
Did you disconnect or reconnect the wire from the distributor that is hanging on the firewall? If I recall that wire will not allow the distributor to advance so that you can time it correctly. Check your manual.
