1986 Bronco II, speed control
303lithgow
Post by 303lithgow »
Anyone know about speed controls? Mine doesn't work. When I bought the Bronco last Friday it didn't work, or the emergency flashers or the brake lights. I replaced on fuze which all three of these items are on and only the brake lights and emergency flasher work.
1990 Bronco II, XLT, 5 speed
1970 F250 Camper Special
XR75ER
Re: 1986 Bronco II, speed control
Post by XR75ER »
I've got an 86 also and the cruise control doesn’t work either. the fuse is different on mine. not connected to anything else. Tried to trouble shoot it today but came up empty handed. I’m under the impression that it has a bad coil in the unit. I have power to it but it won’t energize. I'll do more research and let you know what and if I find anything.
303lithgow
XR75ER wrote:I've got an 86 also and the cruise control doesn’t work either. the fuse is different on mine. not connected to anything else. Tried to trouble shoot it today but came up empty handed. I’m under the impression that it has a bad coil in the unit. I have power to it but it won’t energize. I'll do more research and let you know what and if I find anything.
Thanks, on long trips its sure easier to drive.
XR75ER
Post by XR75ER »
303lithgow
I was headed to the JY today for some therapy & to see about a controller for the CC and as I was going down the highway I thought I'd try the CC. Well it worked. :D Shocked the S out ‘a me. :eek: I figure that it must a been a bad electrical connection. As I said yesterday I had power to the unit but nothing to the coil. You might try to unplug it and clean the connections. Sorry I can’t do any better. :beer:
303lithgow
XR75ER wrote:303lithgow
Where did you disconnect it? At the control switch or at the engine and where if at the engine?
XR75ER
Post by XR75ER »
Sorry I forgot to say where didn’t I. At the controller. Under the hood, on the driver side of the vacuum canister. as seen in the picture.
303lithgow
XR75ER wrote:Sorry I forgot to say where didn’t I. At the controller. Under the hood, on the driver side of the vacuum canister. as seen in the picture.
Okay I see that. When you turn on the speed control is there a light somewhere on the dash?
XR75ER
Post by XR75ER »
nope no light. don't think there is an indicator light.
303lithgow
XR75ER wrote:nope no light. don't think there is an indicator light.
Thanks, I will not be able to check it out for a few days. I'll let ya know how it goes.
