hello, 89 broncoII i just bought it i have a few questions
samuelbarthelemy
Postby samuelbarthelemy » Sat Mar 13, 2010 8:26 pm
I just bought an 89 broncoII 4x4 v6 4speed w/OD. Runs great and tranny is good, but when driving at highway speeds if I hit a pothole or something the steering goes crazy, and the steering wheel is loose like not very reactive, guy I bought it from said it needs a frontend alignment and rear shocks, I was just wondering if that sounds right to you guys. I appreciate any help or tips, thanks. That and any lift kits you guys would suggest, nothing big just so I can fit a little bigger then stock tires on it, or does anyone know what the biggest tires you can fit on 15 rims with stock height.
didittwice
Re: hello, 89 broncoII i just bought it i have a few questions
Postby didittwice » Sun Mar 14, 2010 8:09 am
Hi that sound right my 86 did the same thing I just put tierod on it and that help alot as for the lift the only thing have is add a leaf and that raise the back end up that what I know
samuelbarthelemy
Postby samuelbarthelemy » Sun Mar 14, 2010 9:43 am
Thanks for the reply, im gunna buy new tierods
drofman
Postby drofman » Sun Mar 14, 2010 10:48 am
if it ain't broke, don't fix it. check your tierods 1st. have someone move the steering wheel back and forth with the engine running, E brake on to check for looseless at tierods and draglink.
clem
Postby clem » Sun Mar 14, 2010 6:21 pm
Check the radius arm bushings and the center bushing on the twin I beam system, I'm not sure what the proper name is, but it holds one of the diff sections in place. I would get a good mechanic to go over the front end of any project I get. The front end keeps you on the road, get it checked! -Jeff
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
'56 international s110
C_Sanchez_A
Postby C_Sanchez_A » Mon Mar 15, 2010 4:33 pm
not to change the subject or stealt the topic for you, but are '89 parts compatible with '84 parts?
1984 - Ford - Bronco II
1995 - Hyundai - Accent (R.I.P.)
1994 - Mazda - B3000
myprobe1991
Postby myprobe1991 » Sun Mar 21, 2010 10:22 am
I would check the pitman arm first, it is the easiest thing to check without having to do much. Unless, and I don't think they have them, a rack and pinion. I know ALL Chevy trucks and most Ford trucks have problems there. From my experience anyways.
clem
Postby clem » Sun Mar 21, 2010 4:45 pm
There's NO rack and pinion on these, get your front end checked by a mechanic if you don't know what your looking for.
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
tickturd
Postby tickturd » Mon Mar 22, 2010 6:09 am
im running 29's on mine but i think theres room for 30's but you might hit the inner fender
BroncoII4Life
Postby BroncoII4Life » Tue Mar 23, 2010 12:04 am
I thought it was normal to lose control for a sec after hitting a large bump in the BII, it's what mine does. Steering wheel gets loose and sloppy, very scary. To be on the safe side I'd take everyone elses advise and have those main steering components checked.
dgl6y6
Postby dgl6y6 » Fri Apr 26, 2013 10:30 am
The pitman arm doesnt go bad on these. the ball and socket joint is on the passenger inner tie rod. the pitman arm just has a hole in it. Dont think you can wear out the hole. haha
Users browsing this forum: Bing [Bot], istellabot [Bot] and 3 guests
