84 Bronco Ignition problem
broncoman05
Postby broncoman05 » Sun Jan 31, 2010 6:21 pm
Hey guys, I am new to the Bronco world, just got one Friday. I got it running but we cannot get it to crank with the key, we have to cross the solenoid. We put new starter, solenoid, and key switch on it and still same thing. We also checked the fusses and as far as we know they are all there, someone tried to rig it up, but no wires seem to be cut out. Does anyone have any suggestions about what we could check? Would the ignition switch cause that problem? TIA for anyone that could help.
drofman
Re: 84 Bronco Ignition problem
Postby drofman » Sun Jan 31, 2010 8:09 pm
check clutch interlock swt/neutral safety swt. or if someone put an alarm system on it. The start wire off the ign. swt should be R/LB see if you got power in the crank poss.
broncofan
Postby broncofan » Tue Feb 02, 2010 5:20 pm
does your accessories work with the switch on, radio, fan, wipers ? forward and backwards? if they do its not the switch.
check the grounds. do you get anything when you turn the key on? clicking, even if it starts by jumping the selonoid it still could be bad.check the easy stuff first.
KevinB2
Postby KevinB2 » Tue Feb 09, 2010 8:51 am
I have this same problem on my 87 BII. I have no power to anything with the key on or off. but the motor turns over when i cross the starter solenoid. I did replace the solenoid to see if that was the problem. I havent had a chance to work on it lately so havent tried to much to fix it. Any suggestions on where to start?
smcpeake
Postby smcpeake » Wed Feb 24, 2010 8:41 pm
to kevinb2 that sounds like the ignition switch buddy..
1986 bronco 2 EB
The best solution to a problem is to get rid of it......
Users browsing this forum: Google [Bot] and 5 guests
