Loss of power in 1984 bronco2 2.8 5sp trans
Bronc 2 84
Postby Bronc 2 84 » Thu Jan 14, 2010 8:22 pm
I bought the truck last October it had the stock tires which were i believe 205 70 15.I drove it home fine did a bunch of work to it.Also put 31 inch tires on and i just got it plated about a month ago and when i drove it it won't go faster than 40-45mph unless of course going downhill i didn't fix anything to the motor or drivetrain besides a tune up plugs,wires,oilchange,and air filter other than that wheel bearings,tie rods,new cat,and brakes.So any info i can get will be great.Thanks
1984 Bronco II
Re: Loss of power in 1984 bronco2 2.8 5sp trans
Postby Ranger Dave » Fri Jan 15, 2010 4:31 pm
put the stock tiers back on
broncofan
Postby broncofan » Sat Jan 16, 2010 6:16 am
they need more info, does it surge, idle rough, hesitate,was it cold outside? mine did that found out ice was on the carb.
Postby Ranger Dave » Sat Jan 16, 2010 9:42 am
broncofan wrote: found out ice was on the carb.
it gets that cold in TX
broncofan
Postby broncofan » Sun Jan 17, 2010 5:11 am
Yes, Jan,Feb really gets cold here. Central TX gets a mix of it all, but mostly ice storms if anything. Esp that last blast avg temp was like 15 for 2 weeks. Just now starting to warm up some
