will not idle
dusty1964
will not idle
Post by dusty1964 »
i have a 1984 bronco 2 just put a new carb. on it and it still will not idle it does run but it has a fuel pump someone put on and is on the wheel well, is the fuel pump in the tank and if i replace that should that fix the problem, it seems to be flooding out.
Re: will not idle
no pump in the tank. you might need a FPR
broncofan
Re: will not idle
Post by broncofan »
why does it have a elec fuel pump? did they remove the mech pump off it? is it brand new or reman carb? may not be adjusted right.
