need a cheap small lift
Jlowepa
Post by Jlowepa »
i would like to fit 30 or 31s under the b2 and i was thinking about doing the explorer spring swap. iss that a good idea or should i buy a 2in lift. i dont want a body lift. and i dont do too much wheeling.
Re: need a cheap small lift
xplorer springs will do it. use the 91 to 94 4dr ones
http://rangerdave.freeforums.org/coil-springs-t155.html
Jlowepa
Post by Jlowepa »
do i use the front springs too
yup
Another budget thought is 3 inch fenderwell cutout/flairs. No lift required and will provide ample clearance for your tires.
