2.8 getting no fuel?
neb_scot
Re: 2.8 getting no fuel?
Post by neb_scot »
I think its meant to be blue, but I could be wrong. At least its big.
At this point I usually place a screw driver with a well insulated handle into the spark leads and watch the spark through that too - to check that the quality is not being diminished by the plug. But given that you have already changed the plugs, I figure that wont make a difference.
For what its worth, my '84 B2 need all the electrics replaced on it when I got it - the previous owner had driven this thing into the ground so I know how you feel. I had the plugs, leads, rotor arm and coil replaced. I then had the idle changed. In an effort to overcome the poor electrics, some and some point had cranked up the idle speed. This in turn caused the carb to get real clogged and dirty......
Have you check to see if it has been 'firing' through the carb at all? as well as the exhaust.
Either way, I would check the rotor arm (my memory is they can break a lot) and the coil (or whatever its called) that provides the charge for the spark etc.
Again, Im only a beginner at this stuff - so I may be talking crap. Either way, the guys here have an astounding knowledge of the details of the B2 :beer:
1984 Ford Bronco II
2.8 v6 Engine
Manual Shift 5 speed
4 inch suspension lift
broncojeremy
Post by broncojeremy »
well i got a neww starter today and the motors turning i foundall kindsof wires and vaccum hoses chewed up by rats and patched em up wile i had nothing else to work with so im getting apickup fr the distributor tommorow and hopefully it works if not im dwn to a new distributor i'll be getting some pics up when i cn get it dirty itsnot verry photgenic and it's kindof a storage unit right now
broncojeremy wrote:yeah i hadit running pretty well
broncojeremy
well it was but aparrently water does no good unless it's in a radiator
broncojeremy
I FOUND OUT TODAY THAT THE DISTRIBUTOR IS THE SAME OUT OF A 3.0 WHCH I HAVE SITTING AROUND SO THAT SVS M 100$$$$$$$$$$$ ANDHOPEFULLY SOLVES MY PROBLEM
NOT!!! they dont even look the same,plus there two different ing. systems. who ever told you that.have them show ya there the same
why do you need a dist.????? it was running "pretty well" so you say
broncojeremy
untili gt water all under thehood
broncofan
Post by broncofan »
did you make sure there was nothing on the top of the dist cap before you put it back on?
no crap on the metal inside the cap. plug wires on the right cylinders. change the filter in front of carb? check fuel then too. have someone turn engine over with line off fuel filter.
broncojeremy
new fuel filter pretty convinced it's the pic up coil but im just gonna get a new distributori think cause there are a few nicks on the gear
broncojeremy
so it was thepick up coil in te distributor i replaced it andi drove it around the block and iwas backig up in front of my house andthe damn welded on harmonic balencer fell off agai i found a nother motor from a junk yard for $400 pricy but te only one. i'll buy it assuming i dont go to jail ths tuesday hopefully not because it'll be for 6months i'll miss the good weather, my favorite season and pssibly my babyboy being born. hope my luck don't run out :confused: :eek: :eek: :D :finger: :rolleyes: :rolleyes2: :beer: :beer: :beer: :beer: :beer:
