MOTOR SWAP Q.
MOTOR SWAP Q.
My 2.9 is knocking pretty bad more often than not and instead of rebuilding it, I want to put a 4.0 in it. I found a grea deal on a 92' mazda navajo but it has an auto trans. Ignore wiring setups....I want to know mechanically what to do . .. thanks
Re: MOTOR SWAP Q.
the 4.0 will bolt to your tranny.take the clutch setup off the 2.9 and swap it to the 4.0. save the 4.0 Y pipe
Re: MOTOR SWAP Q.
Well I already have a tranny from a 4.0 on the truck now. and know they will bolt together. i just need to replace the torque converter with the clutch disc/pressure plate. both motors use the same flywheel?
