I'm looking at a Rough Country 4" lift kit with rear springs & the upgraded Nitro 9000 shocks. It says that the single steering stabilizer will not work on Bronco IIs with there 4" suspension and sway-bar drop brackets equipped. I'm new to lifting but it sounds like I can run the steering stabilizer or the sway bar right? Is there a way I can run both while still using the Rough Country 4" kit?
http://www.roughcountry.com/ford_83-97_midsize.htm
Thanks..
Rough Country 4" Lift Question
~'79 Mustang Notchback, 1000hp Project, 410 Dart Block ~ '89 Bronco II XLT 4x4 ~
http://www.MustangAvenue.com
