Bolts breaking
eddie t
Bolts breaking
Post by eddie t »
I have a 88 Bronco ll with the 2.9. The passangers side exhaust manifold is leaking and when I went to remove the bolts holding it on they all broke. Now I used liquid wrench for a week before but it did not help, I had this same problem with the water pump bolts but I was able to back them out. I am having no such luck on the exhaust bolts . Any ideas would be appreciated. Also I was amazed to find that the exhaust header did not use gaskets and one bolt had broken on its own and was causing the leak.
Re: Bolts breaking
i drill um out and use a nut and bolt. its a PITA
Paul
Re: Bolts breaking
Post by Paul »
yeah i had the same issuer on the 2.9 and then on teh 4.0 also. so i drilled them and sued nut bolt and jam nut..
1989 Bronco II 4x4
Mitsubishi 146 5 speed,
Stock D35
235/75/15
4.0L upgrade
NO LIFT
Crop Top
Paul
Re: Bolts breaking
Post by Paul »
Paul wrote:yeah i had the same issuer on the 2.9 and then on teh 4.0 also. so i drilled them and sued nut bolt and jam nut..
