??I need help??
??I need help??
I bought a 85 b2 from my brother and it has some problems. First the engine wouldn't start but I recently found out the problem(the distributor jumped timing almost 30 degress, and my brother ran the truck dry of gas). I got it started and got it moving too. But there is something I didn't notice happening when my brother had it. When I push the brakes to change the gear (example: from Reverse to Drive, it has to go through Neutral too.), it rolls forward about a foot then stops, while I have the brakes on. I need to know if this is a problem with the brake system or if it is suppose to do that. Thanks in advance.
