??I need help??
gullion_a86
??I need help??
Post by gullion_a86 »
I bought a 85 b2 from my brother and it has some problems. First the engine wouldn't start but I recently found out the problem(the distributor jumped timing almost 30 degress, and my brother ran the truck dry of gas). I got it started and got it moving too. But there is something I didn't notice happening when my brother had it. When I push the brakes to change the gear (example: from Reverse to Drive, it has to go through Neutral too.), it rolls forward about a foot then stops, while I have the brakes on. I need to know if this is a problem with the brake system or if it is suppose to do that. Thanks in advance.
Wicked Bronco II
Post by Wicked Bronco II »
Its definitly the brakes cause you truck shouldnt go any where if your brakes were working correctly.
I believe you understand what you think I said but im not sure you realize what you heard is not what I meant....?
