bIIcool
Posts: 19 Joined: Wed Jun 23, 2004 3:16 pm
Post
by bIIcool » Mon Aug 30, 2004 8:22 pm
I have a 1993 Ford Explorer. Recently I have been having my headlights blink/flicker on and off intermittnetly. The dash lights stay stedy. I have checked the fuse connections and the connectors to the lights themselves, but it all looks good. Does anyone have any suggestions??
Posts: 588 Joined: Sun Apr 18, 2004 10:41 pm
Post
by Rockcrawler » Mon Aug 30, 2004 9:58 pm
fallow the wires to were the ground is for the lights. It sounds like a ground problem, so make sure its good and solid.
Posts: 1545 Joined: Mon Apr 19, 2004 5:21 am
Post
by DBrown » Tue Aug 31, 2004 7:16 pm
try pulling the head light connector off and clean the plug. mine did that and it was clogged with mud
Trigger_2001
Posts: 44 Joined: Fri Sep 10, 2004 9:36 am
Post
by Trigger_2001 » Sat Sep 11, 2004 7:09 pm
Maybe you have a cop version. lol
The Bronc Rider (is only 15!!)
OCD4B2
Posts: 227 Joined: Fri Sep 10, 2004 5:10 pm
Post
by OCD4B2 » Mon Sep 13, 2004 7:48 pm
Yea the silicone gel inside will go bad and make it crap. Mine did the same thing after i was power washing it. Most likely its either water, mud or a loose connection.
plowboy
Posts: 311 Joined: Tue Apr 20, 2004 4:52 pm
Post
by plowboy » Tue Sep 14, 2004 6:22 am
It could also be the headlight switch. I had a T-Bird that did that same thing and it was the switch.
