budget lift for my bII
floridamudslinger
Post by floridamudslinger »
Any info on a cheap lift for my bronco i want to clear 33s. will 4 in blocks in back and coil spring spacers in front work?? If so what do i use to keep the front tires aligned? Also will ford explorer suspension work on the bII?
any info will be greatly appreciated thxs!
vabronconut
lift
Post by vabronconut »
3" body lift and some cut out flares are the cheapest, i have never used spring spacers, so i don't know about that.
onewyr
Post by onewyr »
I ran 32x11.50's with explorer springs, spacer in the front and a 2" trim job
clem
cheap lift
Post by clem »
Coil springs out of a ranger stx,with auto trans and air cond have a higher spring rate,thus raising the front. Getting yor rear springs re-arched with aleaf added will do the rear.Fender trimming still req'd.This worked for me until I was ready to go big.
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
'56 international s110
I'd highly recommend staying away from blocks and spacers. Cut those fenders!
