what wire is this
garagedude
what wire is this
Post by garagedude »
I have a 84 BII. I've got a yellow wire, which changes to red, which comes out of the harness on the passenger side that goes to the small terminal on the starter solonoid if thats what it is.... Any ideas on what this is? Also, are any of the wires HOT thats in the harness that runs the stock TFI system? OR, where should I disable all the wiring at that I'm not going to use when doing away with the stock ignition.
I May get Lost But I Don't Get Stuck
84 BroncoII, Locked, Winched, Big Tires,
Ruffinit
Post by Ruffinit »
I'm looking at the wiring diagram, but have not found any plain yellow wires that you're speaking of. I'll check my '84 tomorrow to try to answer your questions. When you say it's a yellow that changes to red, what exactly do you mean by that? Is it spliced or are you saying the color changes after going through a terminal?
garagedude
what wire is this
passenger side, its a yellow wire, then it goes into a black small tube or connector, then its black..its weird, I want to cut it, but scared to yet..I can't tell if its a factory thing or not?? On another section of wires I found six wires rapped together, losely, with no covering at all !!!
