???'S about transmission fluid lines
onewyr
Post by onewyr »
I am close to getting the bronco running but i need to get the fluid lines run for the tranny because i mangled them when i removed the trannyand motor. my questions are 1. does it matter weather the front line or the rear line goes to the high connector on the radiator or to the connector on the tranny cooler. 2. can I run hose for these lines or do I need to run tubing. if i use hose I will still run tubing up past the exhaust manifold.
