sick shackles
sick shackles
Hey all,
Here's some shackles I made. I took a few ideas from different shackles.
Do you think they'll work?
- Attachments
- sickshackle.JPG (25.64 KiB) Viewed 3647 times
You're right, I DON'T understand that Jeep thing
they will work but not how you have them setup right now. just move the shackle mount foward some so your shackle can move when you hit a bump because right now its just going to push and not compress. the best angle to have you shackle at should like this / that way you can ge some extra drop but you probly wont need it with that shackle so you could probly get away with a strait up and down shackle like i have in the rear. From the way it looks it will also be noisy (mine were really loud) so put some ruber between the two metal parts and that should solve that problem. They look good and cant wait to see them in action.
Yeah, your shackle angle is all messed up. It will ride like a tank like that.
I looks like you were going for the "revolver" effect, which when done right will flex well, but perform like shit.
There was a lot of discussion about them when they came out a few years ago, and the general consensus was they sucked. Open up at the worst possible moment etc.....
Or what if you reversed it. Put the dogbone facing the front and shackle angled down and back toward the rear. You'd have to block the dogbone from going up beyond horizontal, but it should allow the shackle to move with the spring. Just another idea, and yes you can say I'm stupid. I've heard it before.
