set_root($pathToTemplates);
} // end (new) FastTemplate ()
// All templates will be loaded from this "root" directory
// Can be changed in mid-process by re-calling with a new
// value.
function set_root ($root)
$trailer = substr($root,-1);
if(!$this->WIN32)
if( (ord($trailer)) != 47 )
$root = "$root". chr(47);
if(is_dir($root))
$this->ROOT = $root;
else
$this->ROOT = "";
$this->error("Specified ROOT dir [$root] is not a directory");
else
// WIN32 box - no testing
if( (ord($trailer)) != 92 )
$root = "$root" . chr(92);
} // End set_root()
// Calculates current microtime
// I throw this into all my classes for benchmarking purposes
// It's not used by anything in this class and can be removed
// if you don't need it.
function utime ()
$time = explode( " ", microtime());
$usec = (double)$time[0];
$sec = (double)$time[1];
return $sec + $usec;
// Strict template checking, if true sends warnings to STDOUT when
// parsing a template with undefined variable references
// Used for tracking down bugs-n-such. Use no_strict() to disable.
function strict ()
$this->STRICT = true;
// Silently discards (removes) undefined variable references
// found in templates
function no_strict ()
$this->STRICT = false;
// A quick check of the template file before reading it.
// This is -not- a reliable check, mostly due to inconsistencies
// in the way PHP determines if a file is readable.
function is_safe ($filename)
if(!file_exists($filename))
$this->error("[$filename] does not exist",0);
return false;
return true;
// Grabs a template from the root dir and
// reads it into a (potentially REALLY) big string
function get_template ($template)
if(empty($this->ROOT))
$this->error("Cannot open template. Root not valid.",1);
return false;
$filename = "$this->ROOT"."$template";
$contents = implode("",(@file($filename)));
if( (!$contents) or (empty($contents)) )
$this->error("get_template() failure: [$filename] $php_errormsg",1);
return $contents;
} // end get_template
// Prints the warnings for unresolved variable references
// in template files. Used if STRICT is true
function show_unknowns ($Line)
$unknown = array();
if (ereg("({[A-Z0-9_]+})",$Line,$unknown))
$UnkVar = $unknown[1];
if(!(empty($UnkVar)))
@error_log("[FastTemplate] Warning: no value found for variable: $UnkVar ",0);
} // end show_unknowns()
// This routine get's called by parse() and does the actual
// {VAR} to VALUE conversion within the template.
function parse_template ($template, $tpl_array)
while ( list ($key,$val) = each ($tpl_array) )
if (!(empty($key)))
if(gettype($val) != "string")
settype($val,"string");
//php4 doesn't like '{$' combinations.
$key = '{'."$key".'}';
// $template = ereg_replace("$key","$val","$template");
$template = preg_replace("/$key/","$val","$template");
if(!$this->STRICT)
// Silently remove anything not already found
$template = preg_replace("/{([A-Z0-9_]+)}/","",$template);
else
// Warn about unresolved template variables
if (preg_match("/({[A-Z0-9_]+})/",$template))
$unknown = split("\n",$template);
while (list ($Element,$Line) = each($unknown) )
$UnkVar = $Line;
$this->show_unknowns($UnkVar);
return $template;
} // end parse_template();
// The meat of the whole class. The magic happens here.
function parse ( $ReturnVar, $FileTags )
$append = false;
$this->LAST = $ReturnVar;
$this->HANDLE[$ReturnVar] = 1;
if (gettype($FileTags) == "array")
unset($this->$ReturnVar); // Clear any previous data
while ( list ( $key , $val ) = each ( $FileTags ) )
if ( (!isset($this->$val)) || (empty($this->$val)) )
$this->LOADED["$val"] = 1;
if(isset($this->DYNAMIC["$val"]))
$this->parse_dynamic($val,$ReturnVar);
else
$fileName = $this->FILELIST["$val"];
$this->$val = $this->get_template($fileName);
// Array context implies overwrite
$this->$ReturnVar = $this->parse_template($this->$val,$this->PARSEVARS);
// For recursive calls.
$this->assign( array( $ReturnVar => $this->$ReturnVar ) );
} // end if FileTags is array()
else
// FileTags is not an array
$val = $FileTags;
if( (substr($val,0,1)) == '.' )
// Append this template to a previous ReturnVar
$append = true;
$val = substr($val,1);
else
if($append)
$this->$ReturnVar .= $this->parse_template($this->$val,$this->PARSEVARS);
else
$this->assign(array( $ReturnVar => $this->$ReturnVar) );
return;
} // End parse()
function FastPrint ( $template = "" )
if(empty($template))
$template = $this->LAST;
if( (!(isset($this->$template))) || (empty($this->$template)) )
$this->error("Nothing parsed, nothing printed",0);
return;
else
print $this->$template;
return;
function fetch ( $template = "" )
return "";
return($this->$template);
function define_dynamic ($Macro, $ParentName)
// A dynamic block lives inside another template file.
// It will be stripped from the template when parsed
// and replaced with the {$Tag}.
$this->DYNAMIC["$Macro"] = $ParentName;
return true;
function parse_dynamic ($Macro,$MacroName)
// The file must already be in memory.
$ParentTag = $this->DYNAMIC["$Macro"];
if( (!$this->$ParentTag) or (empty($this->$ParentTag)) )
$fileName = $this->FILELIST[$ParentTag];
$this->$ParentTag = $this->get_template($fileName);
$this->LOADED[$ParentTag] = 1;
if($this->$ParentTag)
$template = $this->$ParentTag;
$DataArray = split("\n",$template);
$newMacro = "";
$newParent = "";
$outside = true;
$start = false;
$end = false;
while ( list ($lineNum,$lineData) = each ($DataArray) )
$lineTest = trim($lineData);
if("" == "$lineTest" )
$start = true;
$end = false;
$outside = false;
$start = false;
$end = true;
$outside = true;
if( (!$outside) and (!$start) and (!$end) )
$newMacro .= "$lineData\n"; // Restore linebreaks
if( ($outside) and (!$start) and (!$end) )
$newParent .= "$lineData\n"; // Restore linebreaks
if($end)
$newParent .= '{'."$MacroName}\n";
// Next line please
if($end) { $end = false; }
if($start) { $start = false; }
} // end While
$this->$Macro = $newMacro;
$this->$ParentTag = $newParent;
return true;
} // $ParentTag NOT loaded - MAJOR oopsie
else
@error_log("ParentTag: [$ParentTag] not loaded!",0);
$this->error("ParentTag: [$ParentTag] not loaded!",0);
return false;
// Strips a DYNAMIC BLOCK from a template.
function clear_dynamic ($Macro="")
if(empty($Macro)) { return false; }
$newParent = "";
$outside = true;
$start = false;
$end = false;
$start = true;
$end = false;
$outside = false;
$start = false;
$end = true;
$outside = true;
// Next line please
} // end While
return true;
else
return false;
function define ($fileList)
while ( list ($FileTag,$FileName) = each ($fileList) )
$this->FILELIST["$FileTag"] = $FileName;
return true;
// function clear_parse ( $ReturnVar = "")
// $this->clear($ReturnVar);
function clear ( $ReturnVar = "" )
// Clears out hash created by call to parse()
if(!empty($ReturnVar))
if( (gettype($ReturnVar)) != "array")
return;
else
while ( list ($key,$val) = each ($ReturnVar) )
unset($this->$val);
return;
// Empty - clear all of them
while ( list ( $key,$val) = each ($this->HANDLE) )
$KEY = $key;
unset($this->$KEY);
return;
} // end clear()
function clear_all ()
$this->clear();
$this->clear_assign();
$this->clear_define();
$this->clear_tpl();
return;
} // end clear_all
function clear_tpl ($fileHandle = "")
if(empty($this->LOADED))
// Nothing loaded, nothing to clear
return true;
if(empty($fileHandle))
// Clear ALL fileHandles
while ( list ($key, $val) = each ($this->LOADED) )
unset($this->$key);
unset($this->LOADED);
return true;
else
if( (gettype($fileHandle)) != "array")
if( (isset($this->$fileHandle)) || (!empty($this->$fileHandle)) )
unset($this->LOADED[$fileHandle]);
unset($this->$fileHandle);
return true;
else
while ( list ($Key, $Val) = each ($fileHandle) )
unset($this->LOADED[$Key]);
unset($this->$Key);
return true;
return false;
} // end clear_tpl
function clear_define ( $FileTag = "" )
if(empty($FileTag))
unset($this->FILELIST);
return;
if( (gettype($Files)) != "array")
unset($this->FILELIST[$FileTag]);
return;
else
while ( list ( $Tag, $Val) = each ($FileTag) )
unset($this->FILELIST[$Tag]);
return;
// Aliased function - used for compatibility with CGI::FastTemplate
// function clear_parse ()
// $this->clear_assign();
// Clears all variables set by assign()
function clear_assign ()
if(!(empty($this->PARSEVARS)))
while(list($Ref,$Val) = each ($this->PARSEVARS) )
unset($this->PARSEVARS["$Ref"]);
function clear_href ($href)
if(!empty($href))
if( (gettype($href)) != "array")
unset($this->PARSEVARS[$href]);
return;
else
while (list ($Ref,$val) = each ($href) )
unset($this->PARSEVARS[$Ref]);
return;
else
// Empty - clear them all
return;
function assign ($tpl_array, $trailer="")
if(gettype($tpl_array) == "array")
if (!(empty($key)))
// Empty values are allowed
// Empty Keys are NOT
$this->PARSEVARS["$key"] = $val;
else
// Empty values are allowed in non-array context now.
if (!empty($tpl_array))
$this->PARSEVARS["$tpl_array"] = $trailer;
// Return the value of an assigned variable.
// Christian Brandel cbrandel@gmx.de
function get_assigned($tpl_name = "")
if(empty($tpl_name)) { return false; }
if(isset($this->PARSEVARS["$tpl_name"]))
return ($this->PARSEVARS["$tpl_name"]);
else
return false;
function error ($errorMsg, $die = 0)
$this->ERROR = $errorMsg;
echo "ERROR: $this->ERROR
\n";
if ($die == 1)
exit;
return;
} // end error()
} // End class.FastTemplate.php3
