b2 dana 44 swap
87broncoII
b2 dana 44 swap
Postby 87broncoII » Tue Dec 20, 2016 10:22 pm
so im swapping a dana 44 in my 87 and im wondering what to do about the front driveshaft. if i get a tom woods do i have to get a new output setup or is there a simpler way to go?
Re: b2 dana 44 swap
Postby Phillippi » Fri Dec 23, 2016 8:02 pm
If you get a Tom Woods shaft, they do custom ends to make it work. Last time I was on that site, they gave instructions on how to measure the output of the T-case and the front axle yoke.
87broncoII
Re: b2 dana 44 swap
Postby 87broncoII » Sat Dec 24, 2016 9:53 am
ok thanks. but is there no way i could use the stock driveshaft and upgrade to tom woods down the road
Re: b2 dana 44 swap
Postby Phillippi » Sat Dec 24, 2016 9:50 pm
Most likely not. The hard part is that the D44 is physically bigger than the old D28. The U-Joints used are bigger on the D44 and the straps are different sized.
87broncoII
Re: b2 dana 44 swap
Postby 87broncoII » Sun Dec 25, 2016 2:53 pm
ok. i thought that may be the issue. maybe if i had a driveshaft from a old fullsize or f150?
87broncoII
Re: b2 dana 44 swap
Postby 87broncoII » Sun Dec 25, 2016 2:56 pm
at this point i guess i may as well get a tom woods cause i dont know how my tcase would fit the 44 driveshaft or if a fullsize tcase and driveshaft would work. it gets hectic lol thanks for your help
offroadohio
Re: b2 dana 44 swap
Postby offroadohio » Thu Jan 12, 2017 3:02 pm
I am running a 1354 tcase, stock early bronco radius arms and an Olds Bravada front drive shaft fit perfectly.
Sent from my SAMSUNG-SM-G891A using Tapatalk
87broncoII
Re: b2 dana 44 swap
Postby 87broncoII » Thu Jan 12, 2017 7:40 pm
really?? so would an s10 front driveshaft work as well
offroadohio
Re: b2 dana 44 swap
Postby offroadohio » Fri Jan 13, 2017 1:21 am
I would assume but I don't know anything about chevy stuff. I got the measurement of what I needed and went junkyarding.
I will note that my 1354 case has a fixed front yoke. And I am running m5od trans
87broncoII
Re: b2 dana 44 swap
Postby 87broncoII » Fri Jan 13, 2017 12:06 pm
ok well mines not a fixed yoke and i want it to be anyway my next question is how much of a lift you got
Re: b2 dana 44 swap
Postby Ranger Dave » Fri Jan 13, 2017 1:40 pm
i have a 1354 with a stock EB front/rear drive shafts...302/c4
offroadohio
Re: b2 dana 44 swap
Postby offroadohio » Fri Jan 13, 2017 2:50 pm
I have 4.0, m50d with 1354 and eB axles with stock eB radius arms and 4 inch tj lift coils.
87broncoII
Re: b2 dana 44 swap
Postby 87broncoII » Fri Jan 13, 2017 3:13 pm
well i must have a 1350 tcase cause i dont have a fixed yoke. im also doing eb 3.5" coils and f150 leafs with blocks which should all give me 6 inches of lift maybe a little more. anyway i could find a 1354 tcase of just do a tom woods
Re: b2 dana 44 swap
Postby Ranger Dave » Fri Jan 13, 2017 3:31 pm
ide look for the 1354...there in all the early explorers and 3.0/4.0 rangers
87broncoII
Re: b2 dana 44 swap
Postby 87broncoII » Fri Jan 13, 2017 4:59 pm
can i look up the ratios inside them by part numbers? id like it to have the same ratio as the one i have or lower
